Adam Sanchez
Hey all.
I'm looking for a cable and i wanna make sure I get the right one. I need a DVI to VGA cable to hook up my PC to my LCD TV. Which TYPE of DVI plug does a video card use? DVI-I, DVI-A etc?
Also, where is a good place to get such a cable for a good price online?
I have a 3 foot VGA cable that came with my TV but it's not long enough. I had bought a 10 foot extension but the quality is low and the connection is real noisy. The 3 foot cable the TV came with has these "Cylinders" on each end of the cable for I believe supressing noise and I need to find a DVI to VGA cable of about 10 feet... preferably with these same Noise reducers near each end of the cable.
Thanks!
Thanks!
