Mike LS
- Jun 29, 2000
I know this I can't be the first to have this problem, so hopefully there's a good fix for it.
My wife gave me an X1 projector for Christmas, so now I'm having to kind of reconfigure my HT for front projection. I've been using a 32" TV as my display for the last few years, but I don't want to completely do away with the TV. I'll still use it for some gaming and even some movies. I don't want to use the projector for everything I do (trying to save lamp life already), so I want to be able to use the TV when I want to.
Problem is the fact that the TV (with the center channel on top) is in the way of the projector image (I'm using the wall behind the TV...and even if I had a screen, it would still be in the way).
Is there any kind of TV stand that can be lowered? I've even looked at some hydraulic lift tables (like mechanics use) to put the TV on. Then I could hit the release and lower the TV to the ground, then jack it back up to height when I was done with the projector. This isn't the best fix by any means, but might work.
Is there anything else out there that might fix this problem?
