paul pisano
- Feb 4, 2016
- paul pisano
I am wondering when they will come down in price. They are still expensive IMHO. What is the actual difference in picture compared to Blu.
For a quality, large format, well-prepared master - 400% increase in resolution.I am wondering when they will come down in price. They are still expensive IMHO. What is the actual difference in picture compared to Blu.
The days of physical media are, unfortunately, coming to an end. If you want a disc player, you are better off ordering online from retailers like Amazon, Best Buy, Crutchfield, etc. Discount retailers like Walmart and Target have pretty much dropped physical media in most locations, and Best Buy is not that far behind.i find when you go into walmart you don't see them trying to push the technology. in the days of dvd you could go into a store and they would be playing a movie for people to experience dvd.
Does the Sony UBP-X800M2 auto-select Dolby Vision? (I honestly have no idea.) If the answer is no, then you probably want to skip it and go with the more reliable Panasonic DP-UB820K for $399.98.
If you’re troubled by the price, be aware that the same video section is used in Panasonic’s $1,100 player. By comparison, the 820 is a good deal.Does the Sony UBP-X800M2 auto-select Dolby Vision? (I honestly have no idea.) If the answer is no, then you probably want to skip it and go with the more reliable Panasonic DP-UB820K for $399.98.
I have had both the 700 and the 800. I started with the 700 which was good but ran into a few issues, mostly with sound synch and occasional problems with Dolby Vision. I replaced it recently with the 800 and have been impressed with the improvement in image processing as well as better audio. The 800 is also more impressive in terms just basic build.I'd like to ask Todd Erwin (or anyone else for that matter) why to choose the Sony 800 over the 700? My Blu-ray player died and I've looking at those two models. The specs seem very similar. I can afford the more expensive one (800/M2) but I am not sure if you are getting much more value for more money.
Sony UBP-X700 is $159.99, but would not recommend that model.
Panasonic DP-UB420-K is $199.99.
Sony UBP-X800M2 is $249.99.
The latter two are good choices. If you need Dolby Vision, then the Sony X800 is the one you want. It also plays SACD and DVD-Audio discs.
