kevitra
- Apr 24, 2002
I have an SVS 25-31 which I purchased on 09/01/2000. I am considering upgrading to the new (although not anymore) driver. I love my sub, but the upgrade is cheap and I have a possible use for the 'old' driver:
I was thinking that my car could use a little help in the low end. My head unit has great sub controls - variable xover and sub level so I figure I could make a box, add an amp and be set (the xover is better than in my 3802).
To build a box I would need the specs for the SVS driver. I am assuming this is something they don't give out? I don't want a huge tube in my trunk - something semi-compact would be preferred. I could just try one of the pre-made boxes at BB, but I'm sure the sound would be less than great.
I am not looking to rattle the doors off of the car - just a little help in the low end.
Suggestions?
Kevin
Suggestions?
Kevin
