Jean-Francois Masse
- Oct 4, 2000
Hello,
In the next month I'm buying a Sanyo Plv-z2 front projector and I'll probably change my denon avr-5700 for a avr-3805. I really want to add at least one more speaker to the back. I need to buy 2 fronts, a center, and 3 surrounds. It would be very difficult to have 2 back speakers. My room is 13 x 12 so I have to put all speakers near the walls. I know it would be better to keep a distance with the walls but the room is not big enough. My old speakers are all differents. A Jamo center 100, two APM 44 ES from Sony and two rear SS-505-AV (sony). Far form ideal but it's time to change. But I want to keep my sub, a Paradigm ps-1000. I usualy put my Denon 5700 at -15 when I'm watching a film. I don't listen music often in that room. My budget is about $1500 and I can't place big towers anyway. Are Energy take 5.2 speakers an option ? Is there something a little bigger but not too big, especially for the rears. And keep the budget in mind!
