Speaker Wire Recommendations (1 Viewer)
Geoff C
Geoff
I need to connect my Axiom M22's, and Axiom VP150 to my Rotel 1055.
I am currently moving my a/v equipment to a nearby closet and will need wire to span the distance.
So, I will need (3) 35' lengths that will travel along the front wall, then down through some 2" conduit (about 12') under the floor and up into this closet.
Any recommendations on decent, but not ultra-expensive, speaker wire that would match my system and be able to travel that distance?
Links to online companies would be greatly appreciated.
Thanks!
Elinor
I like the clear Radio Shack speaker cable. I have also used generic "budget" cable from high end audio stores, good quality, good pricing.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
If the wire will be hidden, you might want to use installation-grade wire, like this from Parts Express. It’s not pretty, but it doesn’t have to be. And it’s half the price (or less) of the traditional clear-jacketed speaker wire.
Wayne A. Pflughaupt
Brasspineapple
