Brian Dobbs
1) What gauge do you recommend for speaker wire and why?
2) Also, I was wondering if there is a problem with using extension cord wire as speaker wire. I saw a 14 gauge 100 ft. extension cord at Walmart for $8. Assuming the wires are copper inside, what makes it different than stuff you would buy at Best Buy or Circuit City?
thanks
thanks
