Christo Ramo
- Jan 30, 2003
I am in the process of framing out my basement for my home theater. The room measures 18' long by 12' feet wide. Below is a link to a picture of the TV wall. I already know from searching the archives that optimal speaker position is ear level while sitting, but I have a couple issues. I would like to put the center channel right under the TV opening and put the sub woofer right underneath it. Is the sub going to over power the center channel? Is there a rule of thumb where the sub should be placed? Is the center channel going to be OK under the TV or should I place it on top. The ceiling is only 7' from the floor.
Also the should the left and rights be facing straight ahead or on an angle crossing the room? The same question for the rears. They are going to be high up in the back wall corners. Should they be facing straight ahead or on an angle?
Click Here
Click Here
