PatrickS
- Jul 31, 2002
Hi all,
I have little upgrade question. I currently own a HK AVR7000 (2 years running) which I have really enjoyed, however I recently purchased a set of Axiom speakers (M60ti, VP150, and QS-8's), for those of you who are not familar with them, they are very detailed and accurate speakers (all have aluminum drivers and titanium tweets), especially the M60ti mains. While I also love the clear detailed sound of these speakers, on some CD recordings I notice alot of simbilance in the upper midrange. Simbilance that was not there running PSB 4T's and my Denon DCM 370 CD player (which I am still using).
After checking everything including cables and even adding a AH! Noise Killer (which did reduce the simbilance by quite a bit) I still can't enjoy "some" of the recordings I used to enjoy (yes I know that alot of cd's are not recorded that well). I guess that is what I get for upgrading to better more revealing speakers.
Anyway, I have heard that I may be able to tame my speakers a bit if I match them with the right amp, using my avr7000 as a pre/pro.
I have read many reviews stating the Sherbourn 5/1500A is a good match for bright detailed speakers, as it's tends to be on the darker side of neutral sounding (one reviewer even stated he heard some grating simbilance when using his HK AVR510 directly, that disappeared when he connected the Sherourn to the Pre-amp outputs). I also know Marantz is known for it's warm sound. I really do not want to speand more than $1000 if I can help it.
Do any of you that have experience with any or all of these components?
Or if you have any practical suggestions (short of selling my speakers or HK avr7000 or paying more than $1000 for a differant amp),
Please lend your advice?
Patrick
Patrick
