mseanschmidt
- Nov 27, 2007
- Sean Schmidt
I just bought a LG 60PY3D Plasma (1080p), the new DirecTV HDDVR and will be getting a Panasonic BD30K BluRay player this week. I have the HDDVR hooked up with HDMI cables and will do the same with the BluRay Player. I have several questions on the final set-up:
1. I need some help with the correct settings for the DirecTV Box. On the outside of the box there is a button and light you can put at 480i, 480p, 720i, 720p and 1080i. What is this for and what should I put it at? I just learned 720p is better than 1080i, is that correct?
2. While in the Directv Setings Menu I have several things to choose:
- Native- On or Off?
- Screen Format- Pillar Box, Crop or Stretch?
- Bar Color- Black, Grey or Dark Gray? Assume this is personal preference?
- TV Resolutions- It says to SELECT the resolutions my TV Supports???
I can choose to check any of the following-
480i 480p 720p 1080i
Not sure if I should check ALL four or ONLY the 720p? HELP!!!!
3. Audio- Will I get Dolby Digital by just using the TV alone or do I need to add a audio system? I'm not much of a sound guy, have never really cared about the sound experience, I've always been into picture quality. This may be hard for you audiophiles to answer but if I need a additional audio system, is there a cheap basic system you can suggest?
4. Set-up picture on TV??? The factory set DYNAMIC setting is awful! I switched to the televisions MOVIE Setting which makes a little better of a picture. Should I use a different factory setting for the best picture? I remember years ago there was a DVD that walked you through how to properly adjust ALL your tv's picture settings. Is that still around or should I use another method???
I can't thank you enough for any help you can give! Sorry if these are very basic newbie questions!!!!
