oranges325
- Mar 1, 2017
- vincent dea
Hi all,
So I have an REL Q201e subwoofer that I bought used. There's some buzzing sounds and rattling type sound to it. When I lightly press on the sub, the buzzing stops and the sub sounds amazing. Not sure what it is causing the problem, even after taking the driver or to take a look.
After taking the driver out to see what's wrong. I've concluded that the driver is just old ( apparently this was a known issue on this model. )
From taking the driver out the amp still looks like it's still in very good condition. Since the amp is in good condition still, is it possible to change out the driver and use the REL amp to power it? The driver I was thinking about was the Dayton Audio RSS265HO-4 10" reference HO subwoofer 4 ohm.
https://www.parts-express.com/dayton...4-ohm--295-462
I plan to use the same box and everything else just changing out the driver. Is it a true Plug and Play situation? Has anyone done this before? Is it worth doing? Or am I better off selling it for whatever I can? What are my options?
