RoyceDB
Grip
- Dec 10, 2003
okay, I have some old speakers (Soundwave Point Source 3.0), that look really good, but the speakers are starting to go, so I wanted to replace them. Each cabinet contains two 8s, a tweeter up top, then a tweeter facing you.
Now, I need your advice. I really want to use mostly all Adire products. So, I think I can get some Koda 8s, but they are only good up to 1000Hz. Then I can get some Extremis 6s, but they should be crossed at 3kHz-4kHz (according to Adire). Then I wanted to get a nice tweeter up top, like http://www.partsexpress.com/pe/pshow...umber=275-100, then a replacement for the tweeter facing you, which is kind of a weird style, but its very similar to this: http://www.partsexpress.com/pe/pshow...umber=297-408. Any recommendations or comments on any of this stuff? I am open to new ideas and suggestions, especially on the tweeters.
also, they really don't have the exact crossover that I wanted (perfect would be crossed at 900Hz, and 3500Hz), but they do sell Dayton crossovers that cross at 375/3000 or 500/4000. Which one would you recommend.
okay, and lastly, I would like to amp these things to get the most from them. I'm thinking maybe 70wrms to each of the woofers, and about 20 to each tweeter.
thanks in advance
thanks in advance
