Hosmackin
- Aug 28, 2010
- Tom
Hello all,
I'm new to the forum as of 5min ago and haven't searched around much for the info I'm looking for, but thought it might be easier and quicker to get help to ask y'all directly:
I have a Draper Framed projection screen up on the wall in my HT room, which I put up temporarily over a 500gallon aquarium since I don't use the aquarium anymore. Behind that wall is a small 6'x15 aquarium room. I am planning on removing the aquarium this week which will leave a large hole behind the screen.
My question are:
I would like to move all my speakers into the aquarium room out of sight behind the wall. Is it feasible and/or common for speakers to be mounted behind screens and what effect will this have on sound quality?
Any factors or obstacles I need to consider attempting this project?
What would be the best way to mount the speakers, should I build an enclosed box for them or just a base for them to rest on?
Will there be any advantages or disadvantages to framing the wall back up behind the screen or should I just leave it open since the hole is already there?
I also plan to move the stereo equipment into the aquarium room and cut out the wall next to the screen, and build some sort of box with a glass front. Any suggestions for that?
The speakers I have are the Infinity Beta 50's, a Beta250 center, and an infinity sub.
Any input is appreciated!
My question are:
