Pablo Abularach
- May 27, 2002
HI,
I just bought a Marantz SR6200, and I read that the output power is rated 105x5, and I was thing on buying a JBL NPS1 package with a JBL PB12. But in the specs of the speakers it says recomended power 10-100W. So I'm a little worried because I'm new into Hometheaters, maybe you can help me out with my questions
1) Do you think the extra 5W will be a problem.
2) Do anyone know if this reciever really outputs 105x5
3) If the Output is a problem, do you think the N26 or N28 are good options.
Thanks for any replies
Pablo Abularach
Pablo Abularach
