I am planning to purchase a HK 320, but I had just wanted to know about its power ratings. I will use to to push the NPS1 and a JBL PB12 will it be powerful enough to handle those?Thanks
For comparison, I run the AVR110 (50x2, 40x5) with NHT's 'Ones and 'Zeros.
They are 86db efficient like the NSP1 package, and I have no problems at reference.
Although I believe I am definitely at the edge of the envelope.
I keep it at -5db's from reference for demos, just to be safe.
The system you describe will be beautiful!
- CM
The 220 seems to get 'lost in the crowd' for some reason. For the record, it adds 6ch input, 5 more watts/channel, the EZset remote with built-in sound pressure level meter and an on-screen display.
In my opinion, these differences do justify the extra $200CDN this unit costs over the 120. However, they may not hold real value for many customers.
