MikeH
- Nov 22, 1999
I need some advice on where to mount my screen and projector.
Screen is 106" diagonal, 92" wide
Projector will be either the Z4 or 900E
Wall #1 is 8' H x 12' 5" long
Wall #2 is 8' 3" H x 11' long
Distance between walls is 15'
Option #1
screen mounted just above trim on wall #1
Pros- window & light get blocked out by screen
Cons- entrance to living room gets blocked by seating
Option #2
screen mounted on wall #2
Pros- entrance to living room much more accessible, more room on wall #1 for seating
Cons- window lets in light but can be fixed
Unknown - can the projector be mounted just above the window trim? It would be 7' off the floor. My concern is that it would be too high to project a proper image.
My preference would be option #2, I just wasn't sure at what height to mount the screen and the projector.
Thanks for any help you can give me.
Mike
Option #1
Option #2
Mike
