zane
- Oct 21, 2002
how hard would it be to make a piano quality black gloss finish on a square mdf sub, what kind of paint and finish would i use
This endeavor might be worth the time/labor/cost involved, but after my piano black finish experience, I'm done with them.ditto. Never again!
Ronnie
so pretty much the easies and cheapest way I see to do this isThere is no easy way. I second all of the above comments. Attempting this is only recommended if you expect to enjoy the process and relish the challenge.
also i am planing on brushing on all paints and laquers except for maybe the primerYou're going to wind up sanding off almost as much as you put on. Spraying is the way to go, if you have access to a sprayer. You could probably rent one.
Stick to all lacquer based products or you're just asking for something to go wrong. A local paint supply should set you straight. Forget about HD or the like for real advice.
Pete
