PhillJones
- Jan 20, 2004
Morning all,
Please excuse me if I'm posting in the wrong forum. I'm new arround here but I figure that my questions are pretty basic so I'll put it in here.
I've just arrived in the States from England and all the HC terms and technologies are different and confusing for a poor simple limey such as myself.
I'm looking to set up a large screen, probably plasma, home cinema that's multi region and multi standard. I've spoken to one dealer who said he only had one multi standard TV, the Toshiba 42HP83 42" plasma. He says it is pal compatible, HD and prog scan but didn't know if it'll recieve a progressive PAL signal. As I'm sure you know, there is some confusion over the PAL progressive format. So:
1) Are multi standard TVs rare here? Does anybody know where I can find a list of multi-standard TVs, a decent dealer in Boston or any help.
2) Same as above but for DVD players. I figure I need a DVD player that'll output both PAL and NTSC progressive but none of the dealers I speak to know anything about this. Where should I go for help with this.
3) Should I change tack and try and find some kind of seperate de-interlacer or line doubler, or a TV with one built in and just get a multi region player and use the interlaced signal from it?
Sorry about the length of this post.
Cheers,
Phill
Cheers,
Phill
