I feel your pain.
Yeah, but that pain from previous formats finally changed my purchasing behavior for this 4K/UHD and Dolby Atmos formats. I have such a player, but I'm taking my time purchasing such a display or receiver to process these formats. My next display has to be able to HDR and Dolby Vision compliant. The player currently able to process Dolby Vision, but has the necessary technology needed installed, it just needs a firmware update for Dolby Vision.I feel your pain.
Hi Robert,Try three HD-DVD players.
I'm using both remotes. I've been getting mileage out of the * key and, unless I'm missing something, it can't be programmed into my Harmony remote/app/hub.
Okay, here's my question. When skipping tracks on CDs and SACDs this player almost always clips the first fraction of a second on my player. Do you have that issue? I suspect it happens on DVD-As, as well, but don't play them as often. This has been my only frustration (well, dropping HDCD support is also minor annoyance). I suspect this is a baked-in problem since I seem to recall the 93 doing it also.
When going into settings, under Network, consider adjusting BD-Live Network Access. My understanding is that "Limited" should prevent things like Universal trailers slowing down load times without impairing things like firmware updates and CD artwork.
It's all in place!
Should I be thinking about re-calibrating the video and audio of my system with the change in players?
I'm in the same position having the oppo 203 and a 1080p display ( projector). I would say learning what color depth is supported by your TV would be seriously worth exploring.
Since I don't see the numbers which reflect what you're talking about, I guess I'm going to have to stretch my brain a bit more and do some more research.
a 10 bit gradient test pattern
Oppo said the UDP-203 will get a similar firmware update later this year.
I don't have it in front of me but I'd describe it as quick access key to toggling many basic settings (like 3D). I'm new to the Hub-based Harmony so I'm outta my depth. My understanding is that the 203 programming was pretty much the 103/105 ported to the new model number. If that's the case then the * and the HDR/SDR toggle wouldn't have been in the database when I ran set up. I don't know if such features would be added automatically with an update on their servers or if I'd have to manually remove and re-add the Oppo into Harmony. So far I'm just rolling with it. This is a hobby, not something I stress over.Hey, Dave!
It definitely sounds like we've had similar experiences.
I cannot imagine there's a key that is not programmable into a Harmony remote. I'm pretty sure I've read that pretty much any function can be learned--one way or another. But unfortunately, I'm not the expert on that.
I was just looking at the manual to see what the * key was for. So I then found the "Pure Audio" button. That might be one I'd use. We're gonna have to find out about that.
That's amazing that you brought that up...because it is a problem I used to have with my former player (the Pioneer Elite 62FD). If I felt I needed to hear that first second of audio, I use to have to hit the rewind button to start things over. But not with this player. Isn't that odd that it's a problem for you and my new player has actually solved the same problem for me? I will suspect that one of our gearheads will be able to chime in with an easy settings solution to your problem. Let's see.
I'll definitely look into that. I cannot imagine there's any BD-Live content I'm going to want to access. I just figured I'd connect it for firmware updates and see what else having the player connected to my network might bring.
Merry Christmas and Happy New Year to you, too!
That's the firmware I updated with this morning. Again, I haven't had any issues with 3-D so far.The last official firmware (UDP20X-33-1229) was released on 1/19 and was the former public beta that addressed several issues, including dropped frames on 24p content. There's currently another, non-public beta which came out about a week ago that resolves the 3D dropped frames issue, but you have to specifically request it from Oppo Support and it can only be installed via USB/disc.
