Mikel.S
Grip
- Oct 23, 2002
Ok, I just ordered a pair of Klipsch RB-35 bookshelf speakers. The specs are:
FREQUENCY RESPONSE:
45Hz-20kHz±3dB SENSITIVITY:
96dB @ 2.83 volts/1 meter POWER HANDLING:
125 watts maximum continuous (500 watts peak) NOMINAL IMPEDANCE:
8 ohms compatible
I figured this meant I needed to find a receiver with 125 watts per channel. But do I really need one that powerful? I don't see how you match the speakers with the receiver. The receiver I'm looking at is the Onkyo TX8211
Power Output (8 ohm, 20 Hz-20 kHz, FTC)
50 W/Ch
Dynamic Power*
105 W/Ch/70 W/Ch
THD (Rated Power)
0.08 %
Frequency Response
20 Hz-30 kHz (+/- 1 dB)
Would this work well with my speakers? I hope so because it's pretty inexpensive.
I really appreciate your advice
Mike
FREQUENCY RESPONSE:
8 ohms compatible
50 W/Ch
Dynamic Power*
105 W/Ch/70 W/Ch
THD (Rated Power)
0.08 %
Frequency Response
Mike
