I am finally getting close to finishing up on the basement room I have crafted for a HT/listening room. It is 18'11''x 14' with 8'2" ceiling height - double drywall, etc, etc. I am looking at building something to hold my audio equipment, storage for CD/DVD, etc, and of course house my new TV. I am in love with the 60" Sony SXRD picture, and while I will probably wait until it can handle 1080p input, I need to plan for the placement now.
I had planned a spot that is 72" wide, and 24 " deep, which should give it all the clearance it needs and allow me to put a back-light in as well. The question is... how high should the platform be that holds the tv? I understand I want it to present at no more than 30 degrees vertically off center. If I assume a 38" center line for typical eye level seated, and the tv is approx 40 inches, that would put the bottom of the tv only 18" off the floor. That seems awfully low. I was also thinking that I wanted the center channel (a Klipsch RC-7) under the screen to keep the lines clean.... but that would mean the enter would only be 8 inches or so off the floor as the speaker itself is 9 inches tall.
According to the Sony site, there is a 30 degree vertical viewing tolerance. I wonder just how much the picture quality varies within that tolerance. If it is the same throughout the 30 degrees, then I have some slack and can move the TV height up a bit (I'll be approx 10-12 feet viewing distance from the screen which should technically mean that I could raise the tv 2.5 ft. and still be within tolerance (that is if my geometry holds up).
I am probably being very anal, but if I am constructing and have the options now, I guess I want to make it the best I can.
Any thoughts/comments are very welcome!
Jeff
Jeff
