I'm upgrading from a much simpler analog setup with many new components. All have HDMI jacks:
SONY KDL-32XBR4 (TV)
Oppo DV-981HD (upconverting Standard DVD Player)
Onkyo TX-SR805 (HDMI 1.3 A/V Receiver)
Sanus EFAV-II component rack
Older existing gear:
TiVo Series 2
Klipsch 5.1 speaker system
My question(s):
1.
A. I was planning on hooking the Oppo to the Onkyo receiver by HDMI and then another HDMI from the monitor out to the TV. Does anyone know if there are any "processing" or any other kind of possible issues involved here?
B. The alternative, I think, would be to run the HDMI directly to the TV and also run an optical digital audio feed to the receiver. I guess I would then run another HDMI cable out to the TV for the sound. The SONY does not have an optical digital audio jack "in."
* I would prefer solution #A to keep it simple. However, I wonder if pressed into doing #2, would I have to turn the sound all the way down on the TV everytime I use the Klipsch system through the Onkyo? I wouldn't want the TV's speakers competing/muddying my sound response.
I don't know if either the SONY or Onkyo can selectively "dampen" or disengage the monitor speakers in this kind of set-up.
2.
I also wonder if it's advisable to run additional cable interconnects in parallel in such a set-up. Oppo states this is an alternative. One could run a S-Video cable and I guess in my case an optical digital line for sound along with the HDMI cable out to the receiver.
The reason they give is that if there were any "hand shaking" or other issues with the HDMI working with both components, the alternative cables would be a back-up for "testing" purposes. Any personal experience out there in this area?
Thanks for any advice.
TiVo Series 2
My question(s):
1.
2.
