@David Norman Thanks for the advice on the switch. Both switches get 5 star reviews on amazon, but the TP-LInk is half the price.
I think it’s mentioned on this thread the router must be disabled by putting it in bridge mode. When I looked at some YouTube videos, the instructions were unplug the router from power, plug the Eero into the router, plug in the Eero, and plug in the modem. No mention of disabling the modem. Maybe that install process accomplishes that?
If you are going to use your old router as a switch, you must change it to Bridge Mode which disables it's router/wifi function.
The install of the EERO shouldn't change anything on your current router. It's probably easier to not use router though most routers if you go into the ADMIN functions should have a section that tells the device whether to function as a Router/Bridge/Access Point. A straight switch is simple plug and play.
The TpLink Switch is cheaper, but the Netgear often goes on sale and I've just had better luck with Netgear Switches than TPlink, Dlink or Linksys. The ProSafe switches are very nice
Probably a typo, but you don't want to disable the modem
