Good afternoon, We are rebuilding part of our master bedroom. The area we sleep in is raised two steps above the rest of the master bedroom. We have a pass through fireplace being installed and there are 5' wide steps on either side leading up to the sleeping area. I have attached a copy of the floorplan and dimensions are all accurate. The yellow area is where our TV will lower from the ceiling. We will be using an 85" TV. With the distance from the head area of our bed it would be better with a 110" TV but the height makes this difficult for us as the area is only 8'4" high because of the raised floor in this area. The bed has a large log frame that is 45" tall. If we used a larger TV the bottom would get blocked by the footboard of the bed I fear.
Here is my dilemma. Where we will be watching the TV from our heads are really close to the back wall so should I use ceiling speakers for the rear channels or use in wall down closer to ear level . . . but the speakers wouldn't be very far from our heads.
The front center channel I can place in the wall of the fireplace enclosure slightly above the top of the TV and I think this will be okay.
My real concern is the left and right channels. The TV is going to be 76" wide and the fireplace enclosure is only 66" wide. This means I can not mount speakers in the wall of the enclosure without them being blocked by the TV. If I mount them in the enclosure facing the bed low enough to be below the TV then I feel the audio will be dramatically impacted in a negative way (but you guys may tell me otherwise). The other option would be to use in ceiling speakers for right and left channel but I do not read good reviews on this placement.
I have a 150lb dog and another large puppy on the way so freestanding speakers in front of the TV would not work.
I am open to all suggestions on what might work here.
Thanks!!
Bill
Thanks!!
Bill
