OK, I am moving into a new place this weekend, and the room setup is a @#$*@ to deal with. As usual in most newer APT's and houses, the fireplace is in the exact spot that the TV would ideally be...
Anyways, attached is a quick picture of all the basic components, and I was hoping I could get some suggestions for layouts from you all!
I can't really put the TV on the left wall, because the "couch 1" would face away from the fireplace and "couch 2" would block access. I though about putting the TV in front of part of the "sliding glass door", but that would look kinda tack and block access to the back yard.
The cable input comes in from the TOP RIGHT CORNER currently. The TV and Component shelf would be somewhat crammed to fit in there for one. Also it puts the TV at an angle which I hate (but could live with if necessary). Lastly if I put the TV in the corner, how would I setup the 5.1 speakers? It seems the RIGHT FRONT CHANNEL would be blocked by the way the fireplace sticks out?
ACK!!
See my problem? Anyways, any help would be GREATLY appreciated!!
ACK!!
