wmk1986
- Jul 20, 2010
- Matthew
I need help with a problem I am having that I cannot figure out, but it seems there should be a simple solution. My terminology is not solid but I will do the best I can.
I have (had) a nice 5.2 home theater surround sound system. The receiver is blown, I can only guess from lightning, I love the speakers and want to keep them. They are expensive and great quality. I want to replace the receiver and keep the existing speakers. The only problem is I have 2 non powered subs. I believe the correct term is passive. The subs were powered directly from the old receiver.
I am having trouble finding a receiver that will support this. It seems all the receivers available only have a rca jack out to a sub, that hooks to a powered sub. This will not work for my subs, so what do I do.
Is there a way to hook up my existing non powered subs to a receiver like this? I was thinking a cheap standalone 35w stereo amp, but I don't know how this would work. Is there a way to take the signal from the receiver, (which usually connects to a powered sub) and hook it to a stereo amp? It confuses me because of the one signal coming out of the receiver, and the amp takes a left and right signal, and then sends out a left and right signal. Is there a way to hook subs to a left and right and get a mono sound? or just anyway to make this work?
Does anyone have any suggestions on how to make this work. In theory this should be simple, and I am a pretty advanced electronic user, I'm just relatively new to home theater. I also am on a tight budget. I would like to keep it around 200 dollars. I have found some decent receivers less than 200, I just don't know how to hook up the subwoofers to this.
Please help, any and all suggestions are welcome.
