oedius
- Jun 6, 2009
- Steve
Hi all,
My first post. Very frustrated! Upgraded to 7.1 Onkyo HT-S790 HTIB from Sony 5.1 Niether reciever has HDMI but both do have optical. On both recievers, only the surround speaker output is working. I eliminated possiblity of any speakers or speaker wiring being defective by process taking turns connecting each speaker to A/V speaker outputs known to be working. All speakers and wiring are good. This is same for both recievers. The 7.1 Onkyo would also not output from it's surround back jacks but, as with Sony, would only output to the one pair of surround speakers.
I have Direct TV HD reciever and a Toshiba DVD player that are both connected directly to a 50" Toshiba HD DLP TV via HDMI. Then from TV, only one optical cable to A/V reciever. I just use input selection of TV to change source.
The only thing I haven't tried yet is to hook directly from satellite reciever and DVD player to A/V reciever versus routing through TV. I have already been into setup menues of satellite reciever and TV to make sure of proper settings. Like I stated previously, I at least made sure that all speakers are good and speaker wiring is correct. Could there be problem with the optical cable? I thought they either worked or didn't. Should I buy a new one?
BTW, I forgot to mention that the powered sub does also work. I just can't figure out problem with center, right & left front, and the surround back speakers (7.1 Onkyo).
I already called Bestbuy and Geeksquad would charge about $140 for service call.
One other I am now thinking from reading previous post is that maybe there is compatability problem between TV and A/V? If so, perhaps connect optical cable directly from DVD player to A/V reciever? And then, will I still get decent audio if I connect TV to A/V with analog cables?
Please help,
Steve
Please help,
Steve
