I am building a ported sub. I was planning to line it with polyfil batting. Is there anything better to use? What is the best way to attach it? I have a staple gun. Thanks in advance.
Morning, I built a 214L Adire align ported. I asked the same questions. Responses were that the "egg crate" foam was more for standing waves and that it was not needed for the low frequencies of a sub. I also think the "fill" is for loading to make the enclosure larger in volume.
did you design the ported enclosure with the lining in mind? the batting will change the volume 'seen' by the driver, so if you don't take it into account it will change the tuning of the speaker.
Lining won't make that much of a difference in perceived enclosure volume seen by the driver, and the lining is more for filtering out higher frequencies (like male vocals) that might emanate from the sub-driver while in use.
