DerekCV
- Feb 21, 2005
Ok so I went out and auditioned the JBL E60 and E80 at Best Buy last night. I like the E60 better, which sort of surprised me so I even doubled checked on the back of the speakers themselves just to make sure I was looking at the right ones. I thought that the E80 sounded a little hollow and boomy, almost like there was a set up problem, and the E60 sounded brighter and smoother. Both sounded better with a sub going. Has anyone else felt the same way??? I’m defiantly not a connoisseur of sound quality or anything, just looking to spend some money. I would have really like to check out the E90 or E100 but they didn’t have them there. I’m just afraid that what I heard on the E80 was associated with dual drivers and that there would be a similar effect on the 90 and/or 100, anyone comment?
Also how do you know you have a big enough set up? I know that to some there is never a big enough set up, and I feel the same way about bass… always have. But how do you really KNOW that the E80/90/100 are really for you, with out trying all of them out in your house, is the a broad line to follow, or not. I imagine that this is a very open ended question that has no right answer, but I thought I would ask it.
Thanks!
Thanks!
