FS: iScan Ultra Home Video Processor / De-interlacer / Line doubler (1 Viewer)
Chris PC
For Sale:
iScan™ Ultra Home Theater Video Processor
Specifications
Motion and source adaptive video deinterlacing
Horizontal and vertical scaling for full Aspect Ratio Control
Full-frame Time Base Correction
Vertical chroma filter for removal of MPEG decoder chroma artifacts (chroma upsampling error)
Source adaptive processing
NTSC sources
Film - 3:2 pulldown detection & correction (inverse telecine)
Computer graphics @ 30 frames/second
Video @ 60 fields/second
PAL/SECAM sources
Film - 2:2 pulldown detection & correction
Computer graphics @ 25 frames/second
Video @ 50 fields/second
Advanced Source Transition Management provides seamless transitions between source types
Autodynamic threshold control provides robust 3:2 pulldown and 2:2 pulldown detection and correction, even with noisy source material
Motion detection on a per-pixel basis
Four input fields used to determine content of each output frame
Cubic interpolation for pixel calculations
Diagonal processing reduces "jaggies"
12 bit video digital-to-analog converters (DACs) with 4X oversampling
High performance, multi-standard video decoder
High-quality adaptive comb filter with 2D Y/C separation
Six video inputs accept standard NTSC, PAL, and SECAM signals
Two Composite inputs
Two S-Video inputs
Two standard-definition Component Video inputs (Y-Pb-Pr)
One Video Passthrough input accepts HDTV and PC signals
Analog Video Ouput
15-pin VGA PC-type HD connector
RGB or YPbPr colorspace
Discrete H, V sync, composite sync, or sync-on-green (or Y)
480-line progressive scan video @ 31.5kHz horizontal scan rate for NTSC sources
576-line progressive scan video @ 31.25kHz horizontal scan rate for PAL/SECAM sources
RGB - 0.7 Vpp, TTL sync
YPbPr - 0.7Vpp, sync on Y 1Vpp
Digital Video Output - Digital Visual Interface (DVI) for digital RGB interface
Controls
Input select
Aspect ratio select
Full frame
letterbox
squeeze mode
Picture controls with memory for each input
Brightness
Contrast
Saturation
Hue
Y/C Delay
Sharpness (two levels - edge enhance and fine detail)
Output Controls
Color space
RGB
YPbPr
Sync
Curtain
Analog/DVI
DVI format
Power - Universal AC mains input: 100 - 240 VAC @ 50 - 60 Hz
Consumption < 10W
Sleep mode - automatic 30 second timeout indicated by POWER indicator color change
Physical Dimensions 10.4" x 17"x 2.2" (26.3cm x 43.3cm x 5.5cm) (with desktop feet)
Standard 19" 1U 1.75" rack mount option (brackets not included - see ordering information)
Weight
Shipping - 12.9 lb. (5.9 kg)
Unit (without power supply) - 5.45 lb (2.5 kg)
iScan Ultra SKU number: MM504
Optional rackmount brackets (call or email for price) - SKU number: 99-1211
Asking $425.00 CDN (or equivalent $USD)
A good deal for someone starting a home theatre. Add whatever dvd player you want, preferably not a cheapo model, since the iScan Ultra will de-interlace just about anything, including video games, video camera's, standard defintion cable TV and video ala VCR.
Would prefer a local Toronto or southern Ontario sale, but will consider shipping elsewhere.
Chris PC
Anybody? I'm getting desparate to sell. Would people be more interested in my iScan HD??? I can't really afford to keep the HD anyways....and could live with the Ultra for my purposes.
If I get a good offer for the Ultra, I may still sell it, but I'm more inclined now to sell the HD.
