Mark.D
- Oct 2, 2002
Well its been a while since I posted... we finally made the move up here to Blue Ridge, Georgia
We also just closed on some land upon which to build a house
So, once we get the land paid off shortly, we're gonna start building... Good News, one of my patients is an A/V installer for Custom Car/Home Audio in Atlanta... he said he can even get me A/V equipment wholesale
Originally about a year ago, I was looking at the SharpVision Front Projector, but then HTF members suggested the InFocus because of their new "Faroudja" chip... I think they recommended the InFocus 7200, but now I see they also have 9500 model out that puts out 5200 ANSI!
So what do you think of the 5200?
Aspect Ratio: Native 4:3; supports 5:4, 16:9
Brightness Uniformity: 85%
Contrast Ratio: 700:1 full on/full off
Data Compatibility: UXGA, SXGA, XGA, SVGA, VGA, and Macintosh®
Digital Keystone Correction: +/- 30 degrees
Display Technology: 1.8" PolySilicon TFT
Dot Clock: 230MHz
H-Sync Range: 15-120kHz
Image Offset: 100% positive/negative vertical offset
Image Size (Diagonal): 30.3"-600"/76.9cm-1,524.0cm
Lamp: 2x150-Watt UHP, 1,500 hours
Lens Shift: Motorized
Min/Max Projection Distance: 5.25'-104'/1.6m-31.7m
Native Resolution: XGA (1024x768)
Operating Temperature: 5-35 degrees C/41-95 degrees F
Power Supply: 100-120V, 200-240V at 50-60Hz
Projection Angle: +/-9 to +/-12 degrees (approximately)
Projection Methods: Front/rear and ceiling/desktop
Throw Ratio: 2.0-2.6:1 (distance:width)
V-Sync Range: 50-120Hz
Video Compatibility: HDTV (1080i, 1035i, 720p), EDTV (480p), NTSC 3.58/4.43, PAL, SECAM, PAL-M, and PAL-N
Zoom Ratio: 1.3:1
Dimensions: 17.3" (W) x 23.8" (L) 8.9" (H)/43.9cm x 60.4cm x 2.7cm
Weight: 45.2 lbs/20.5kg
CONTROL
Mouse Control: USB, PS/2, and serial
Projector Control: RS-232
INPUT SOURCES
Standard:Input 1 (modular): DVI-I, audio in, mouse control; Input 2 (modular): 5xBNC (RGBHV, RGBS, RGB, YPbPr, YCbCr), audio in, mouse control; Input 3 (modular): 2xBNC (composite, Y,C video), S-video, audio in
OUTPUT
Audio: 2x3-Watt stereo
Brightness: 5,200 lumens in 2-lamp mode, 2,600 lumens in 1-lamp mode
Number of Colors: 16.7 million colors
Output Sources: RS-232 out and audio out
OTHER
Approvals: UL, cUL, CE, FCC Class A, TUV, C-tick, NOM, and IRAM
Audible Noise: Less than 45dB
Menu Languages: English, French, German, Spanish, Italian, and Japanese
WARRANTY
Lamp Warranty: 90-day limited lamp warranty
Projector Warranty: Two years parts and labor (excluding the lamp)
Contents:
Proxima PRO AV 9500 projector
Wired/wireless remote control with mouse
Wired remote cable
AC power cord (U.S. and European)
Macintosh adapter
Mouse cables (Serial, PS/2 and Macintosh)
DVI cable, VGA cable
DVI/VGA adapter
Composite video cable
S-video cable
Audio cable
RCA to BNC adapters
Owners manual
Lens cap and dust cover
What do you think is "Hot" this year for projectors?
Mark
Dot Clock: 230MHz
Zoom Ratio: 1.3:1
CONTROL
INPUT SOURCES
OUTPUT
OTHER
WARRANTY
Contents:
Wired remote cable
Macintosh adapter
DVI/VGA adapter
S-video cable
Audio cable
RCA to BNC adapters
Owners manual
Mark
