Jacob_St
- Jan 15, 2000
I just noticed that MGM's Bandits DVD out Tuesday is a DVD-18. Does that mean replication problems for this type of DVD have been solved and studios will start using it?
I seriously wasn't aware there was a problem with DVD-18. Can anyone point my in the right direction to get some more info?
The best thing I can tell you is to do a search for dvd-18 on this site. You should get alot of info about manufacturing problems that way.
No, it's gold on both sides. Widescreen is on one and fullscreen is on the flipside. I'm hoping this isn't a fluke decision and MGM will start using DVD-18 more often. This would help reduce the amount of separate fullscreen widescreen editions released.
Does that mean that Widescreen+Extras on one side, and Pan & Scan only on the other meaning that the video bitrate will be higher on the P&S Side, Damn!
Or maybe the extras are copied on both sides, or spread out on the 2 sides... I'll find out tuesday when I buy it.
MGM has been using DVD-14 for a lot of its releases lately, and I suspect the studio will be using more DVD-18 as well. I think it's a good move, because they can do away with multiple releases for widescreen and pan-and-scan, which means we can find widescreen MGM movies at Blockbuster and most retailers.
Except if they put their Barcode Stickers on the Widescreen side... I had that problem when I rented Wicked (Which is a dual-sided Widescreen/P&S disk) and I managed to remove the sticker without damaging the disk and I reglued it on the Fullscreen side!
DVD-18 is basically dead. WB has quit using it, Artisan, and MGM will do so soon enough because of the ludcrous error rate in manufacturing (close to double DVD-9's)
Do you have any actual numbers concerning DVD-18 failure rates? I keep reading posts like yours, but nobody ever has any actual data to prove how uneconomical DVD-18 is.
The trend, at least for MGM, is going in the other direction. They've ramped up DVD-14, and they seem to be showing a renewed committment to DVD-18 when needed.
What i fear most is that the other studios(such as PARAMOUNT,UNIVERSAL and FOX) will follow MGM's move to release their S.Es in DVD14 or DVD18 format.
Let us look at the fact that,no matter what DVD type-DVD5,DVD9,DVD10,DVD14 or DVD18,disc thickness will still be in a constant thickness of 2mm(or 3?).More data film layers,lesser coatings...is that logically correct?Lesser coating,means lesser durability!This will happen,especially we don't just watch the disc once,we watch it over and over again for about 6 times per year(approx.) or even more!
To me,i would prefer/suggest the studios to go for more popular/durable disc type...DVD5,DVD9 and DVD10.
What you should fear most is the fact that studios are beginning to release P&S-only versions of films to DVD. This is because DVD has gone mainstream, a large portion of the public wants "fullscreen" and retailers are resistent to stocking multiple versions of every title because of consumer confusion and limited shelf space.
In all the time I've been reading about DVD, here at HTF and elsewhere, no one has ever offered evidense that DVD-18 is less durable because of its thickness. If you have something to back up your assumption, I'd like to see it.
In the meantime, if you get your wish, we will most likely start seeing even more P&S-only releases, especially with catalog and "family" titles.
If we're smart, we'll start embracing DVD-14 and DVD-18 as a welcome way to consistently get OAR releases while reducing consumer confusion and retailer complaints of stocking multiple versions of titles.
