Scott_AH
- Sep 26, 2002
What's the difference between the decoding of a receiver that offers "DTS-ES Matrix compatibility" and that of a receiver that "DTS-ES Discrete" capability?
Scott
Scott
I find that hard to believe wes. i think that all theyd have to do is just simply not mix the mono surround channel info into the 6.1 discrete mix, just mix the surround mono info right into the back channel only.DTS ES 6.1 is not seven new channels compared to DTS 5.1. So all they have done is added one more discrete channel which is the ES channel. The 6.1 Surround L/R still are playing the 5.1's info which have the matrixed ES info in them(that is why if a ES sound track has 6.1 discrete it will always have the matixed). If ES Discrete is played with the new discrete channel with out any removal you will hear the exact same sounds in all three surround channels when the sound is intended for the ES channel! Just because the term "Matrix" is given to the EX and ES does not mean the EX/ES info will not be heard when played in 5.1, This is In-Phase mono info it is heard just not pulled apart and separated into the three channels.
Dobly Digital EX and Matrix ES goes through the same removal of the In-Phase info from the surround L/R channels just as Prologic removes to the main vocals out of the front L/R channels and then places it in the Center channel. Other wise you would have the main voices coming from all three front channels at equal volume.
I'm not down talking ES 6.1 just telling what has to happen in order to make it work.
Wes
the problem with this approach is that the ES decoder would still subtract the discrete back-channelIf the In-Phase Mono was not put in to the Surround L/R on that 6.1 track there would be nothing to remove. I do know there has to be a certain amount in order to blend with the ES channel, I'm not a sound engineer but believe it could work with a little better results.
But Heck, I'm happy with my Prologic decoder doing my matrixed EX/ES decoding!
Wes
