Do subs need to be shielded (1 Viewer)
Brad Newton
of particular interest are the SVS subs. Due to limited "space", I may be forced to have the sub sitting next to an older 36" direct view tv. Will this cause any problems?
Todd Alexander
If it is not shielded and it is within a foot of a TV, you will get color disrtortion on your TV set. You don't need a shielded sub, unless it iswithin a few feet of your TV.
Robb Roy
Even next to the TV you might not have a problem as the SVS' driver is at the bottom and the TV is presumably on a stand.
Alex F.
It depends on the sub and the TV. For instance, Sony's Wega TVs are very sensitive to magnetic fields. An unshielded Mirage sub caused CRT discoloration in our 36" Wega from three feet away.
