Jay H
Replaced my rear passenger side brake rotor on my 05 Subaru Outback. To do so, I had to use a pretty long M8 bolt to back the rotor out of the hub because the emergency brake (drum type) was tight to the rotor and getting the adjustment nut was a PIA. Eventually when I got the rotor off, I could easily turn the e-brake shoe nut adjustment to loosed the shoe so I could put the new rotor on easily.
I always thought that there is one rear wheel that has the emergency brake shoe on it, not both, but I think I recall trying to change my rotor in the rear driver side and encountering the e-brake shoe that didn't want to come off... So I thought I'd be in the clear with the passenger side one... not!
Anyway, I have to replace the driver side one tonight and I guess I'll have to see if I can have better success with that one. Did mfgrs switch to having the e-brake lock both the rear wheels sometime ago or have I just been incorrect in my thinking?
Also, do any of you know if I have to reverse the logic in loosening the e-brake shoe? for the passenger side, by using a screwdriver and turnnig the nut down towards you, this loosens the shoe, turning the nut up and away tightens the shoe. However, for the driver side shoe, is this logic reversed? Should I be turning the nut up and away to loosen?
Jay
Jay
