Joe Wilmore
- Jan 8, 2002
Has anyone read the review in DVD Etc. regarding this subwoofer? The reviewer liked it better than the Velodyne HGS 18. I haven't heard of anyone purchasing one of these.
*Theoretically*, because of the 3 14" drivers (2 passive, 1 active), the Def Tech should be OK in this regard.I'm not sure I follow your logic. You have one powered driver and two passive radiators. What does that have to do with distortion levels?
This sub is rated to go down below 11hz! Did DVD ETC comfirm this claim?That would require measurments,since people can't hear that freq.But as Brian pointed out it would fail to deliver for sure.
My old Def Tech tower speakers were rated to 20hz but it was lucky to muster @35hz where after the level would drop like crazy.They rate their speakers very "optimistically" shall we say?
I just browsed a review of the SuperCube Reference at Media Play last night. I believe it was the current issue of DVD etc.
I have never been a fan of their reviews (lack of data, and the I just don't like their scoring scheme), but they are generally written well. Their non-review articles is the their saving grace IMO.
Anyway, the reviewer actually pointed out the claimed 11Hz ... and said that he decided to make an exception and actually do some measurements.
Froma what I recall ... in normal placement, he was getting under 20Hz of usable bass ... and in corner placement, pretty much hitting the claimed 11 Hz.
He gave it a 99, and specifically stated that the only reason he didn't give it a 100 is because nothing is perfect. He basically said it was one of the best subs he's ever heard.So the reviewer did take measurements.
So the reviewer did take measurements.So where is it? Is it a graph like RTA?
So where is it? Is it a graph like RTA?I'm thinking it's in the magazine, going by what the poster said the reviewer wanted to take measurements to see if the claim holds true.
I'm thinking it's in the magazine, going by what the poster said the reviewer wanted to take measurements to see if the claim holds true.I figured as much, but someone who read that thing could at least post the figures and method it was gathered with.Without that it's just a "blowing in the wind".
The Def Tech SC Ref boasts a freq response of 11 to 200 Hz. Quite frankly, at first, I found this measurement listed on their spec sheet to be unbelievable. ... Whereas we typically do not measure eqp here at DVD Etc., I put the SC through the paces using a USAC bass test disc with freq sweeps from 5 to 200 Hz. ... Away from corners, the SC Ref generated audible output (perhaps psychological) beginning at 15 Hz consistently. Moving the unit into the corner produced astounding results, with audible output at 12 Hz.So there you have it. I'll just add though, that what I think of as "audible output", means the -10 dB point. So I'd reckon it maybe doesn't go quite as low (and as loud) as the PB2+, but it does have a much higher WAF. The SVS is 18" w x 25" h x 28" d vs the more or less 17" cube of the Def Tech. But then again, you can't cheat physics and logic reinforces that a bigger box has the potential of going lower, and the SVS is still probably a little cheaper too. (You get a retail discount on the Def Tech, but no sales tax on the SVS but $100 for shipping.)
