John Doran
- Jan 24, 2002
i'm currently trying to decide which route to go:
1) cinepro 3k6 SE III Gold
2) 3 bryston 14B ST's
which option do you think will yield the best (i.e. most appreciable) sonic results?
i'm in canada, and the currency exchange is killing me, so, although the cinepro lists at $7500 USD, that translates into an easy $11,000 CDN, and more, with the inevitable 15% tax up here.
the 14B, however, goes for $7,000 CDN retail, so i could probably get 2 of them for roughly the same as 1 Cinepro. The third would come later (I don't even have 6 speakers, anyway).
In the meantime, I would use my Denon 5800 to drive the center channel.
there's just so little information that i can find on the technical spec's for the bryston, and very few reviews that seem satisfying to me - as satisfying (convincing) as the reviews i've read for the cinepro, anyway. although i would be easily able to audition the bryston at a store nearby, i am obviously unable to listen to the cinepro. so direct (subjective) comparison is out.
and the S/N of the 14B is only 114db, while it's 124db on the cinepro...
anyway, i'd really appreciate some input on this...
thanks a lot.
thanks a lot.
