greg baker
- Feb 13, 2003
I Know I am probably going to get hammered for this but here goes. I have JBL S26's in the front and the S-center II in the front. For some reason it has started having major problems with the sheilding. I have lifted it up, put it on a sanus tv shelf, put MU-metal underneath, and basically unless I lift it a foot off of the TV then I am screwed. I have heard this is a common problem with this speaker and I am not real hip on getting the same one. JBL is not that interested in helping me becuase I bought it from the dreaded non-authorized dealer. (I have learned my lesson) No other speaker is Timbre matched and I am not interested in scrapping the S-26's. Can anyone recommend a solution or a good center channel speaker. Thanks,
Greg:b
Greg:b
