GregoryHGilbert
- Oct 2, 2003
I've read the basics (all 150 pages) and have more questions...Also, I hope this is the right section for this question.
So, I want to build a HT and got the thumbs up from the spouse (SAF - will be tough). One wall is already standing, the other 4 will be built. It is basically a 13' X 17' room, but one corner is cut and should be large enough to hold a 42" screen, giving the room a diamond shape. The spouse has already picked out a couch that will pretty much fill the center of the room, but will have to turn slightly to the left 30 degrees to view the screen in the 'cut corner'. The back of the room will be the existing wall and have the only window and here come the questions. Budget around 15-20k, but would love to have it lower than this.
1. Can this sort of set up work?
2. To appease the spouse that be, she would love itty bitty speakers, but is willing to compromise to ones that are in the walls and well hidden. Would like it to be at least 5.1 and 7.1 surround is even better.
3. Trying to get everything now and not upgrading later, so if I should set up for 10.1 or anything let me know!
4. Should I run cables in the walls? What cables 12 ga or lower, right?
5. Wife is pretty sure she wants a plasma screen, but I have been telling her about projectors and she seems to be ammendable to that. I think she would love to hide the subwoofer under the couch, but I don't know if there is enough clearance, would building a hole below the couch help, or should I put it in the wall that is going to house all the components.
6. What components should I get? Will the projector do video games like PS2 - I think I have seen warnings not to play some games on a projector or something.
7. I think a HTPC sounds cool....
8. Any other tips/tricks. - Since in planning stage there is room for change in the plans, but time is running out...Help!?! Thanks for reading this long post.
-Greg
-Greg
