Tim Simko
- Mar 13, 2003
My fronts & center have bi-wiring terminals. I want to see what this sounds like. How would you terminate this run at the amp? It only has one connection for each speaker. Would you just twist the two (2) lines together? Would banana plugs accept this amount of combined wire? I have a Yamaha DSP-A1 and it will not accept spades, unbelievable!
Also, would you hook up a sub directly to this amp or running the fronts thru a pair of Velodyne FSR-1200's?
Thanks in advance. Hope I didn't run on. Wonderful forum. Glad to be a part of it! First post.
