Ronnie Ferrell
- Jul 16, 2002
Your questions are better suited for a direct email to Danny. That way it will be straight from the horses mouth.
Take care,
Ronnie
Take care,
Ronnie
When I was checking ou the GR websight I noticed the new version AV-3 and I was wondering what the difference between it and the AV1+ is.The current A/V-3 uses a pair of 16 ohm 6.5" woofers (an 8 ohm speaker) while the A/V-1+ uses two 8 ohm 5.25" woofer (4 ohm speaker).
The new version of the A/V-3 is set for release sometime in late spring and will use two 16 ohm versions of our M-130, 5.25" woofers.
The new A/V-3 has several pros and some cons when compared to the current version.
The current version is capable of playing down lower (-3db of 40Hz) and with the deeper enclosure (like the one use with our Paradox-3) it is capable of reaching a -3db of 35Hz.
The newer version will not play down as low, but in the transmission line enclosure it will have it should have very tight and very fast bass response with a -3db of 47Hz. It is also possible that the transmission line design could extend the -3db down point to around 42Hz.
The newer version needs less air space and has a 1" narrower front baffle. This could help the WAF a little.
The small floor standing, rear terminated transmission line design also means no extra money spent on stands
The newer version can also use the same front baffles and grills as the A/V-1+, and we already have these made with Neo magnets that are in stock and ready to use.
The new 16 ohm 5.25" woofers will also allow me to offer a 8 ohm, side laying MTM, fully shielded center channel, in a sealed enclosure.
I think the pros may outweigh the cons. 20Hz to 40Hz is what sub-woofers are for anyway.
With regards to what Dan said about the manufacturers I use:
Peerless of India has had great quality control in regards to consistency and performance.
They are just not as well known because they do not produce a bunch of drivers for the hobbyist market, and none of their drivers are distributed here in the US.
They do make a few stock drivers that have limited application, but I think more often than not they are used to provide a sample of their work.
I have them do some things for me that they don't normally do, like adding bumped back plates and vented poll pieces. Plus, our new woofers required a larger motor structure that had to be custom built as well. The end result is excellent.
TB is just now making a name for themselves. I started using them about 6 years ago. At that time they had great capabilities just no direction. They could build anything, but did not know what to build. I think they may have now found their niche with some of the full range drivers. I would say that their capabilities are now very good and their QC to be fair.
Sorry for such a long post, but there seamed to be several issues to address. I hope I covered the questions.
