SteveK
- Jan 10, 2000
I have an Avia question. I've calibrated my Sony Wega using the Avia calibration disc (basic menu settings only). Most of the levels were very easy to determine the proper setting (or at least the proper range). However, I found the "Picture" or "Whiteness" test much more subjective. Even when turning it all the way up, I did not notice any blooming on my TV. Not wanting to overtax my new television, I would estimate I have the "Picture" setting no more than halfway up (the Sony Wega doesn't show numbers or percentages for some reason). I hope I have the terminology correct, as I don't currently have access to my TV, but it's the setting that determines the whiteness level. Particularly for DVD, this seems to result in some very dark images, particularly for indoor shots. Daytime outdoor scenes seem perfect; however low-lit scenes seem VERY dark.
Do I perhaps have the whiteness level down TOO low? Is there another test other than the pulse/needle test that would give me a more precise result than the blooming test?
On a perhaps related issue, my Panasonic DVD player has a "black level" menu setting. The user's manual recommends it being set to "darker" for component video and "lighter" for S-Video or composite video. I am using component connections and do have it set to darker, and I also calibrated using these settings. Would I be better off using the "lighter" setting instead of "darker"?
Any advice would be much appreciated.
Steve K.
edited to eliminate redundancy
Steve K.
