Brian Dobbs
I don't understand the power specs of this amp. I am not familiar with plate amplifiers so can someone please explain to me why it can run 250w at 4 ohms, and only 180w at 8 ohms? For those of you who know my situation, I'm thinking of substituting my stereo receiver for this amplifier. Also, how many 4 ohm speakers could I run off of this amplifier? thanks
AVA250 Specifications
POWER 8 ohms, 180W - 4 ohms, 250W
Crossover Frequency 40 Hz to 160 Hz, second order Butterworth
Frequency Reponse 14 Hz to 160 Hz, +1/-3 dB
Phase Rotation 0 to 180 degrees
Gain Range 30 dB
EQ Filter Q 0.96
EQ Filter Frequency 18 Hz
THD Less than 0.1% THD at rated power
S/N Greater than 103 dB at rated power
Weight 12 pounds
Overall Size 10.5" wide by 10.5" high
Mounting Cutout 9.25" wide by 9.25" high
Mounting/Front Depth 3.5"/1"
Input Voltage 115/230V switchable, 50/60 Hz
High pass outputs First order Butterworth, 125 Hz
(on speaker level outputs only)
PRICE $179 each
Gain Range 30 dB
EQ Filter Q 0.96
Weight 12 pounds
PRICE $179 each
