Matt Fisher
- Aug 4, 2004
So here's my situation - I work in a stock footage archive for a major cable network, and the way we operate is that most of the footage in our library is either on 3/4", 1", betacam or digibeta. We recently came across a number of boxes each containing 20 or so 16mm negatives on cores. We know what this footage was used for, however we have no clue what is on each reel as we don't have any sort of logs. We've never had this type of problem before because the only big project we've dealt with on film was 35mm newsreels which we jumped at the opportunity to transfer into hi-def and found every foot of footage to be incredibly valuable (feel free to check out http://www.thoughtequity.com/video/home/mot.do if you're bored).
So my question is, can anyone suggest the most efficient and affordable way to scan through these? The two most reasonable options seem to involve buying a pair of split reels and picking up either a tabletop viewer or a projector and going through each one. I'm a bit worried that since I'd have to pick up a used machine/viewer on eBay or a message board classified, there's a chance they might not be in good shape, and I don't want to risk scratching frames or possibly damaging sprockets. The films are in great shape, so if we find that most of the content looks like it's worth upgrading, I suppose we might either look into getting a telecine or shipping off to a transfer house. But since there seem to be hundreds of reels, that will be quite costly if we wind up not finding any of the footage useful.
Any suggestions? Know of someone specific to contact or perhaps another forum to check out? Much thanks-
MF
MF
