Bob_A
- Jul 30, 2000
Have you guys seen the Tom Nousaine data on the Adire Audio Dharman?
From Adire Audio's website:
We sent a Dharman to legendary reviewer Tom Nousaine to measure. After all was said and done, here's the results of the 10% SPL tests:
Average SPL 25-62 Hz: 107.9 dB
Average SPL 20-62 Hz: 105.9 dB
Bass Extension: 20 Hz @ 96 dB SPL
Maximum Output: 114.6 dB SPL @ 32 Hz
Here's the 10% THD limit SPLs Tom measured in his large 7500 cubic foot room:
20 Hz 96 dB SPL
25 Hz 102 dB SPL
32 Hz 114.6 dB SPL (system at maximum)
40 Hz 111.8 dB SPL (system at maximum)
50 Hz 108.1 dB SPL
62 Hz 103.1 dB SPL
Tom summed it up: "This system has excellent output especially at this price point. Both output and extension put the unit in the top quartile of subwoofers without regard to cost." None too shabby for a sub-$600 subwoofer!
You can compare this to the others on the data list:
__________________________________________________ _________
STRYKE HE15 proto-type 115.3 / 16hz~99 / 25hz~106
VELODYNE F1800 - 111.9
20-39cs - 109.5 / 20hz~91dB / 25hz~105.8dB
VELODYNE FSR15 - 109.1 / 16hz~90.1 / 25hz~103.1
MISSION 700as - 108.1 / 25hz~102
Paradigm PW2200 - 108 / 20hz~84 / 25hz ~104dB (112.8dB peak)
VELODYNE HGS15 - 107.7 / 16hz~89.1 25hz~102.1dB
Paradigm Servo15 - 107.3 / 27hz
VELODYNE SPL12 - 107.1 / 20hz ~90 /25hz ~ 99
HSU RESEARCH TN25(w/250w) - 107.1 / 30hz
HSU RESEARCH VTF-2 - 107.1 / 20hz~9325hz~99dB
Cerwin Vega cvt300s - 107 / 16hz~80db / 20hz~92(112.4dB peak)
KLIPSCH KSW300 - 106.0 / 25hz~92 *
Cerwin Vega LW12 - 106.0 / 20hz~89
POLK 650 -105.9 / 25hz~90
Infinity 1.2s - 105.5 / 20hz ~90 / 25hz~95
BW asw1000 - 105.4 / 25hz~92.4 *
MK mx125 mkII - 105.3 / 20hz 89 / 25hz 95
VELODYNE ct150 - 105.3 / 20hz~82(111.4dB peak)
JBL D112 - 105.2 / 25hz~95
KLIPSCH KSW12 - 104.9 / 25hz~90
Boston Acoustics PV800 - 104.4 / 20hz~85
Infinity interlude100 - 103.5 / 25hz ~ 94
BW asw2000 - 103 / 29hz *
PSB Subsonic6 - 102.7 / 25hz~94
Sound Dynamics rts1200 - 102.1 / 25hz~92(110.9dB peak)
Infinity IL100s - 102dB / 25hz ~94dB
VELODYNE ct120 - 101 / 20hz~87
MK - mx105 -100.6 / 25hz~86
ATLANTIC TECH 272 PBM - 100.5 / 20hz~85
INFINITY hps250 - 100.2 / 25hz~82(112.8dB peak)
KLIPSCH LF10 - 100.1 / 25hz~90
PSB subsonic 3i - 100 / 28hz *
MISSION ms70asa - 100/32hz~92dB
SUNFIRE Jr. - 100 / 25hz~95
VELODYNE VLF810 - 100 / 25hz~91
Canbridge - 100 / 20hz ~82dB
POLK PSW350 - 99.8 / 25hz~82
VELODYNE FSR12 - 99.7 / 20hz
JAMO E 8sub - 99 / 25hz~ 86dB
VELODYNE VA1012 - 99 / 29hz
JBL PB10 - 99 / 25hz 82
POLK RMDS-1 - 98.6 / 25hz- 77
VELODYNE FSR10 - 98.4 / 20hz
BW asw2500 - 98 / 25hz~86dB
ENERGY ES12xl - 98 / 28hz *
Paradigm PDR10 - 98 / 25hz
PHASE tech power8 - 98 / 25hz~84
Polk psw250 - 97.3 / 32hz~91
ATHENA S3 - 97.0 / 25hz~87
Energy S8.2 - 97 / 25hz ~82
VELODYNE CT80 - 97.0 / 25hz~81
MIRAGE frx s10 - 97 / 25hz~84
JAMO sw505 - 97
Klispch KSW10 - 96.9 / 25hz~85
TANNOY PS110 - 96.8 / 20hz~71 / 25hz~84
CANTON AS25 - 96.8 / 25hz~80
MK V-1250thx - 96 / 25hz~86
Atlantic technology 4.5 - 96 / 25hz~82
ATHENA S2 - 96 / 25hz~87
ACI titan - 96dB / 25hz~80
PSB alphasubzero - 95.2 / 32hz~88
Aura Lss-107A - 95.2 / 25hz~73
Celestion cswII - 95 / 25hz~78
GALLO MPS-150 - 95.0 / 25hz~86
ENERGY ENCORE - 94.4 / 25hz~78
ENERGY XL8 - 94 / 25hz~78
POLK PS-120 - 94 / 32hz -no SPL given
Wharfedale Modus - 93.1dB
Paradigm PD8 91.4 / 25hz~73dB
MK k9 - 90.1 / 25hz~77
Cerwin Vega hts15 - 89 (107 from 40-100hz) / 39hz
ATHENA P1 88.5/ 32hz~85.5
-----------the following use a 25-50hz range----------
Based on the data...the Dharman seems like a bargain for a sub-$600 subwoofer. Maybe the most bang-for-the-buck that you can currently find with a non-DIY subwoofer? What do you guys think?
20 Hz 96 dB SPL
25 Hz 102 dB SPL
50 Hz 108.1 dB SPL
62 Hz 103.1 dB SPL
JAMO sw505 - 97
