What is a cheap way to get power from ac wall unit to dc car amp.There isn't one.
What you are talking about is called a power supply. Yes, you can buy 12v power supplies from Radio Shack for about $50, but they will only be good for a couple of amps. Your car amp will need much more. A 200W amp, for example will need 200*1.5(efficiency factor)/12 = 25 amps. A 25A power supply will run you at least a couple hundred bucks. As Wayne suggested, you might be able to get by with a 25A battery charger and some big filter caps or a battery for smoothing. Voila... you're back up above the price of a plate amp. Save the car amp for your car.
