reed hunt
- Oct 15, 2006
- Reed
Greetings all.
We are currently adding on to our house and are planning to use one of the two additional rooms for double-duty - as a new play room for our girls and as a nice, though relatively modest HT room...
With regard to the latter (and working with currently open walls) I have had our low voltage guy and electrician wire the room (about 12x16) for a 5.1 surround system, though I have not actually run any wire for a sub (since I don't know exactly where I will locate it).
The equipment will be located in the room's closet and will have a dedicated line with enough juice to handle potential power. We have also had speaker wire run along the trusses and into the front wall - ones that will allow for power and L, R, and C speakers. However, my wife is balking at front, in-wall speakers, preferring to not cut holes in the walls and instead simply pull the wires through (tastefully) and use small, free-standing speakers. While I originally protested, I may well lose this battle and have to fall in line. I can live with this, as I already have available two small Polk speakers and a Polk center channel speaker as well.
So, without confusing things too much more, should I run two more rear wires for possible future 7.1 uses, is there a strong downside to using free-standing front speakers and in-ceiling rears, assuming I stay with Polk for the rears, and should I run sub speaker wires to an assumed location or, since this would probably be along the rear wall, are sub wires less of a challenge to deal with later in the game?
Thanks in advance for your thoughts.
