MattJS
Grip
- Sep 23, 2002
Hi all,
Still a noob, so forgive the clarity or lack thereof of the following questions...
Let's start with setup...
Sony STR-DA4ES
Polk RM6600 Speaker set
I am going to attempt my first tune-up this weekend using the S&V disc along with a radio shack SPL meter.
1. Is there anything to watch for when calibrating? In other words is there anything a rookie could screw up and not know it?
2. I have the front speakers mounted about 9 feet apart 5 feet from the floor with the TV (43" Mitsu RP) and the center channel speaker mounted very close to centered between them. I have the rears just behind the primary listening position, and about 6 feet off the floor. That said, this may not be the ideal speaker placement, but I had to do it while finishing the room, so I am pretty much stuck with the speakers where they are. What's the question you ask? Does calibrating the system help to make up for the mis-placement if any of this setup?
3. Does the S&V disc help as well with tuning the picture of the TV? I have some issues with DirectTV having some "wavy" effect as well as the guide menu seems to 'flex' slightly if you really look at it. This seems to improve slightly after the recvr warms up. Is this a result of routing the video through the recvr? Another problem I have noticed on the TV even before the HT was hooked up was a shadowing of white letters or stark white graphics. I am at a loss because I have tried fixing the convergence, but my eye still sees all 3 colors no matter which direction I move convergence of the lenses with the TV's basic setup.
4. Dumb question, but since I am really not familiar with how decoding is performed, Should I get 1 or 2 more rear channels since I am using a 7.1 decoder, or does a unit like mine 'know' when to use the 5.1 versus 6.1 or 7.1 setup? I would like to make sure I am getting the most until I can afford to add the other 2 rear channels.
Thanks in advance for any help you all can offer, I have done TONS of reading, but sometimes, it is hard to find really specific answers with the search function, it seems as if I am not looking for the right info, but hopefully that will change as I learn more, and feed the beast that now has a strangle hold on my wallet.
Matt
Sony STR-DA4ES
Matt
