Bit of a confusing bit of information from the Yamaha Canada site about the ability of the RX-V577 AVR (my receiver) being able to pass through 4K data to a 4k TV. Early on the page it states this:
"This model will support HDMI 2.0 connectivity*.
It will support 4K Ultra HD 50 Hz/60 Hz signal pass-through to output motion-smooth high definition videos.
*Firmware update to support this feature has been available since 2014 Jul.
*This model doesn't support HDCP2.2. HDCP2.2 compatible equipments are needed to see 4K contents which are encypted with HDCP2.2."
Later it states this:
"4K Ultra HD pass-through for super high resolution images
This AV receiver provides advanced HDMI features including pass-through of 4K Ultra HD, which is gaining popularity. 4K Ultra HD refers to four times the resolution of a 1080p display. This receiver is capable of passing the 4K Ultra HD data from the source to the monitor, for image clarity far beyond present standards."
I know my ignorance is showing, but will this receiver be able to be used if I buy a 4K TV? Thanks
