Should I block one of the ports so I can get lower sound or should I leave them all open? With no blocker in it is set at 25, with one blocker it would be at 20. Help me out, it arrives monday.
Try it both ways after calibrating it in each tune and hear what you favour Jessy. Your going to need to be the judge. You might like some material better in the 25 Hz tune and then other material in the 20 Hz tune. Usually when tuning to 20 Hz, it only requires a couple notches up on your SW setting.
